1. Dismiss Notice
    Dismiss Notice
How-To: DIY Bungs for Tanks, Oil Bags, Fenders, etc...
Discussion in 'The Garage' started by Punkskalar, Jan 18, 2011.
  1. Punkskalar
    Punkskalar Hugh's HandBuilt
    Ok, so this post is gonna be a little misleading. I'm not gonna teach you how to make a weld-in bung from a chunk of soap, or how to carve one out of an old fencepost. I am going to show you how to avoid the annoyance that is standard bungs.
    Most of us have bought bungs at some point or another. They are cheap, easy to use, and just make sense. But, I have found that most of the cheaper bungs on the market look like the ones pictured below.
    [​IMG]
    There ins't much wrong with this style, they do the job. But, how many of us have played the "Put a bolt in the Bung, try to hold it in place, tack weld it, twist and tug on the bolt to line up the bung to exactly where we want it, break the tack weld while doing so, and then repeat the whole process" game?
    No need to answer that one, I think that anyone who has used a bung like this, especially in a piece of tubing, has run into that problem. I can't think of how many times I have drilled too large of a hole and dropped a bung into the tubing or had to play the above game to get it lined up exactly where I want it. The other problem with most prefab bungs, is that they are larger than 1/2" OD, but how many of us own bigger drill bits? While working on a fuel tank mount this week, I decided to build a whole new style of bung. Here comes the DIY part :D
    Since I was mounting a fuel tank, I was planning on a standard 5/16-18 thread. I cranked up the lathe, and made a few bungs just like pictured above. Then I decided to turn down the main section of the bung so that it could easily drop into a 1/2" OD holes (something I could drill with my standard drill set, and a hand held drill)
    [​IMG]
    With this style bung, you CAN do it yourself with nothing more than a 1/2" Drill Bit, and a welder. Even if you don't own a welder, you can use some Silicon Bronze Filler (sold at most welding supply stores) and use a map gas torch.
    Here you can see that the bung drops into a 1/2" Hole just fine. The larger OD keeps it form dropping into the hole, and so long as you have drilled the hole in the right location, you won't need to twist, pull or pry the bung into the proper location.
    [​IMG]
    Look ma, no hands!
    [​IMG]
    Now you just need to weld it in. (Silicon Bronze filler was used on these, but you can MIG, TIG, MAPP and Silicon Bronze, Coathanger, whatever you are comfortable with)
    [​IMG]
    I went ahead and finished out the front tank mount just the same.
    [​IMG]
    Most people would probably like the bungs to sit lower on the frame, but for a tank mount, I like to keep some room under the tank. These give a nice 1/8" or so under the tank for wiring, zip ties, foam, etc... If that doesn't work for you, then once you have the "Do It Yourself" bungs installed, you can grind them down lower to the tube.
    If you need a set of these bungs, feel free to PM me or check out my Blog. I'm hoping to keep doing more Tech How-To's and Tips for us here as well. Have something you want done or think needs a tech How-To?? Email me or contact me and I'll see if I can make it happen... I really think that the Tech on this site is amazing, and we need to keep it going.
    Hugh
    http://hughshandbuilt.blogspot.com/
    Direct Link to Blog Post for more details - http://hughshandbuilt.blogspot.com/2011/01/fabricator-parts-do-it-yourself-bungs.html
  2. Ironsled77
    Ironsled77 XS650 GRAND HACK
    Nice work Hugh. Looking forward to seeing more.
    Hightower-Ash98 likes this.
  3. Downer
    Downer XS650 Addict
    Really good info I just welded some nuts on my faux oil can
  4. These are nice....
    Tom
  5. gemiller
    gemiller XS650 Enthusiast
    I know this thread is old but I just wanted to up this as I just purchased a set from Hugh and this made my life way super easy and I actually like the little rise off the rail it puts the tank.
  6. alko13000
    alko13000 XS650 New Member
    Thanks for the tip, good idea!
  7. itrguy
    itrguy XS650 Addict
    But I love fishing bungs out of tubing...... Nice job Hugh!!
  8. I am Carbon
    I am Carbon shade tree mechanic
    They made my tank install a breeze
  9. xs650dreamer
    xs650dreamer XS650 Junkie
    hey hugh you have anything like this so we can convert from oe petcocks to the screw in type ?
  10. some one makes then I have seen and used one I'll have to track down were I got it.it may take me a few min./hours ha ha.
  11. xs650dreamer
    Haha alright thanks man
  12. Here I found the how to on www.650motorcycle.com/petcock.html hope it helps.
Share This Page
