Robert Pirsig had a great section in his book "Zen and the Art of Motorcyle Maintenance" where he philosophizes about working on bikes and getting "stuck" on a problem.
“If your mind is truly, profoundly stuck, then you may be much better off than when it was loaded with ideas.
The solution to the problem often at first seems unimportant or undesirable, but the state of stuckness allows it, in time, to assumes its true importance. It seemed small because our previous rigid evaluation which led to the stuckness made it small.
But now consider the fact that no matter how hard you try to hang on to it, this stuckness is bound to disappear. Your mind will naturally and freely move toward a solution. Unless you are a real master at staying stuck you can't prevent this. The fear of stuckness is needless because the longer you stay stuck the more you see the Quality-reality that gets you unstuck every time. What's really been getting you stuck is the running from the stuckness through the cares of your train of knowledge looking for a solution that is out in front of the train.
Stuckness shouldn't be avoided. It's the psychic predecessor of all real understanding.”
