1. Dismiss Notice
    Dismiss Notice
Ideas For Mounting Crankcase Breather
Discussion in 'The Garage' started by anomie, Jun 21, 2011.
Tags:
  1. anomie
    anomie XS650 Enthusiast
    35
    0
    6
    Hi all,
    So I mistakenly ordered the following crankcase breather from xs650direct:
    http://www.mikesxs.net/products-40.html
    Part #15-0682, I messed up the order, intended to order the breather filter with the diecast mount bracket so I could bolt it onto the frame. Anyways, enough of my stupidity-- Does anyone have any ideas on how to mount the above breather? My fab skills are non-existent at this stage and I don't really want to leave it dangling. Any hints at all would be appreciated, I'd really appreciate some ideas :).
    I have removed the stock airbox and replaced it with pods so that is not an option.
  2. anomie
    35
    0
    6
    Wow, I feel pretty stupid now. But I used one of the frame mounts for the plastic cover that used to cover the old airbox. If there is a better position, I'd still like to know.
  3. blackbetty
    blackbetty XS650 Junkie
    786
    2
    18
    Most guys just use a short section of hose and a $3 brake check valve facing the filter so the motor can recycle anything that comes out.
    I'm having a tough time finding a clean way to mount this myself. Don't just want it dangling....
  4. 5twins
    19,264
    10,509
    813
    The power brake check valve is the cheapest, simplest, and cleanest set-up I've found so far. It fits perfectly into the end of the stock hose and is light enough that it needs little, if any, additional support. You can zip tie it to the sidecover tab if you like. I did so on the right side because the valve wanted to rest right on top of the filter. The left side needed nothing .....
    [​IMG]
  5. ontherocks
    ontherocks XS650 Addict
    106
    1
    16
    Just get some hose from your auto supplier. Mine didnt even charge me. Attach filter to your breather and you'll be good to go. Easy peasy.
    [​IMG]
  6. xschris
    xschris from earth
    469
    15
    18
    usa
    This is what I use.:thumbsup:
  7. littlebill31
    littlebill31 Smells of Raw Fuel
    I use the same as 5twins. It's tiny and works great. I had a larger filter on there, but the damn thing kept, somehow, getting in the way.
  8. kvanderploeg
    kvanderploeg The Dutch Terror
    It's all about the angle of the dangle.
    [​IMG]
  9. 5twins
    19,264
    10,509
    813
    You guys will be relocating those once they start belching oil all over your carb tops, lol.
  10. xschris
    xschris from earth
    469
    15
    18
    usa
    4k miles and still the filter is dry.:shrug: Why should it leak oil? Unless there is a issue with the engine.
  11. kvanderploeg
    Overfill the oil too much and you'll see it in the breather, otherwise it should remain fairly clean.
  12. XSLeo
    I have the power brake check valve in the hose with about 18 inches of 3/8 hose from the valve to below the engine. Any oil mist that gets out of the engine coats the hose and is all the filter you need.
  13. ReycleBill
    ReycleBill Part Time Tyrannicide XS650.com Supporter
    I bought the exact same filter and never used it. I ended up doing the power brake check valve trick.
  14. YL82
    YL82 Perpetual Restorationist
    Any value in installing a filter on that barbed side piece if I decide to route the check valve someplace other than toward my new pristine K&N Pods?
    Any need to install 2 of these check valves? I still have both of my breather "Nostrils" intact. I enjoy the balance of symmetry as much as the next man, but will cap one off if need be.
  15. thelowlife
    thelowlife XS650 Addict
    I bought the check valve from xs650direct.com (mikesxs.net Canadian version) and this is what I did with it.
    [​IMG]
    I filed the raised edges a little bit to slip on the check valve
    [​IMG]
    Then drilled and taped a set screw to hold it in place. Looks almost factory to me.
    [​IMG]
    Put your filter on how ever you'd like.
  16. ReycleBill
    Mine exits above the chain. If any oil ever does leak out that's where it's most needed.
  17. Anyone tried to tie it in to the exhaust so it will pull a crankcase vac?
  18. YL82
    Lowlife, What you did looks pretty damn slick. I'll put that one down for a future mod for sure.
    Thanks, Recycle Bill !
  19. ReycleBill
    There's a long thread here somewhere where I suggested tying it back into the crankcase via some sort of PCV valve arrangement but the general consensus (saner heads prevailed) talked me out of the idea. But the exhaust?????
  20. I have seen it in several forms over the years Mr. Gasket makes a kit for your drag car, uses the exhaust passing over a small tube going in to the header. Suzuki gsxr 600,750,1000 and hayabusa have passages drilled down into the top of the exhaust ports that pulls pressure from the crankcase via a hose
Share This Page
