Hey everyone, I'm pretty new to the site, and have only posted once before. I bought an 81 XS650 Special II from a co worker a few months ago. Turned out the rotor was bad, I got it rebuilt, and with a new battery, she fires up. Anyway, with the choke pulled out on a cold start, this thing idles at what I think is a pretty high rpm, with some slight popping out of the exhaust, which is leading me to believe I have an intake leak. Once its warmed up a little, you can push the choke in and it idles at an rpm which still seems a little high still with slight popping outta the exhaust. I can't give exact rpm's cuz the tach is screwed up. I also have some top end tapping, which I'm thinking is caused by the valves being out of adjustment. I also plan on checking cam chain tensioner, etc.
Anyone have any input as to some things I can check on this bike as far as the idle/popping and the top end noise. I used my mechanics stethoscope and pretty much pin pointed the noise to the top end/valve area. I have some bobber type ideas for this baby, but I wanna get her runnin' right first obviously.
Thanks in Adavance!
Thanks in Adavance!
