tkurt
Hi guys, another electrical question...
I was getting erratic voltage on the road, and after parking the bike now I'm getting no spark. My bike had been running & charging well.
I get 11.5V at the alternator brushes and the rotor looks OK (5 ohms). No spark when I flip open the points with the key on.
I'm getting 0 volts on the brown wire at the kill switch, so I started checking the ignition switch.
The ignition switch voltages I have, with key ON:
red wire: 0 V
brown wire: 12.5 V
red/yellow wire: 0 V
blue wire: 12.5 V only when key turned to Park
Continuity tests:
Red – blue are continuous when key is in Park
Red is infinity to any ground when the bike is off.
Brown and red/yellow read infinity with key on.
So the brown-red wiring connection is bad, right?
Is it ok to wire them together to get home? I should still be able to use the kill switch to turn off the bike still...
Again, thanks in advance for your help
red wire: 0 V
brown wire: 12.5 V
Continuity tests:
