madeindetroit
Trying to get my bike running and I think I have one of two issues, too rich from the carbs or my coil is weak.
Randomly the bike kick over fine and fire right up. Idle and run with choke out.
I push it in and it lowers idle and things are good. Other times I kick and kick and kick and nothing just poofs of fuel.
When it does run
I will then adjust timing to where it says fire on the PMA sticker. Usually by the time I push the timing light out of the way the bike will die.
50/50 shot of it kicking back over and starting. usually it wont start back up and I have to retard timing to get it to start again. then repeat the process above to full circle back here.
I was reading into the cabs but I cant find what style I have. I read that the needle had steps on it and I could make it leaner but lowering the c clip. Well I took my needles out and no luck its non adjustable.
Its a xs650 thats punched over to a 750. Running short open exhaust and no filters (frame is in way).
When it does run I can rev it up and it pops out of the exhaust. Will run good at low RPM but then as I start to accelerate (higher rev) will run like crap.
Any ideas people? Here are the carbs I have.
Can I make any easy adjustments to lean it out some? Or do I need to buy something.
When it does run
