Tomterrific
XS650 Junkie
The thin wire iridium electrode not only lets teh spark jump easier (on one plug with a waste spark as Pete already mentioned) but the thin wire electrode doesn't quench the initial flame kernal as does a thicker heavier conventional center electrode. This helps even on the 'wrong' side of a waste spark ignition.
The Autolite #63 is a hotter heat range than the NGK #7. This gives better carbon burn off than a colder plug but is less safe at high speed or with a powerful engine. I ran NGK #6 (hotter than #7) for a while and they ran so clean I thought I might try them full time. The colder #7 has not given problems so I stuck with these as I take the old girl over 100 every now and then. I still run points and the original coils so non fouled plugs are of more concern with my ignition.
I have not had the plugs out in 2000 miles. Maybe I ought to check them! :^)
Tom Graham
Tom Graham
