Belle
Okay, so the other day I mentioned to someone a 17:34 final was too small; for me it is. I received a 13 tooth front sprocket today & took a close look to substantiate my fears as to why it won't work.
First off--13t is ~6.13mm in width & 17t is ~8.88mm
Secondly--13t has ~74mm diameter & 17t is ~92mm
Thirdly--530 chain lightly rubbed assembly unit (retainer washer & bolts); I ground the washer a little & the chain ran smooth through the hills but the bolts are hex sided & push against the chain, that's trouble, maybe with some allen head bolts it would run more smooth. I tried with some from the side cover but wasn't happy enough with the clearance; still a little rubby, & I don't want to spend the money or time right now to cut it back & get it just right.
The spindle mated just fine & I think with a 14t I can get the trouble free clearance I desire. Spacing/alignment was difficult due to the width differences but I used some
1" ID washers and chopped a shim from some old sheet metal to get the mock-up & it all seemed to align well enough.
I'm gonna order a 14t, should get that in about 7-10 days.
All-in-all seems possible.
14:34= ~2.43:1 final drive
