So first time on this form and i have not found anything related to this subject and i seems as though there are some smart fellows out there.
I have a 1982 heritage special 650 all stock except for the proper ngk plugs with proper gap and the problems is this; i go to start it and sometimes it starts within two three rotations of the engine. Other times it takes five or so seconds to fire, yet other times i crank it, stop, crank it, stop because it will not start. leave it for a minute or five and it may start or may not. If i use the kick start it starts every time without fail. The bendix gear and spring have been replaced. A known good/fully charged battery has been used and also another battery wired in to make sure that there was plenty of juice. At 1.5 turns of the air/fuel mixture screw the problem is there also at 2.0 turns and 3.0 turns. It has one coil for the bike with two wires, of course, so I was thinking of testing the wires but they do not look like they just unplug from the coil. The only one thing that stands out a bit is at idle there is a pop out of the exhaus every now and again at idle.
Any insight would be great thanks
