hi guys... i,d probably run these plugs purely for no fouling,,, but at the moment its not a problem ... ,,,,,,in australia my local guys want $28 each... so i will be buying some frome mikes when i order some other must have items regards oldbiker
Update: finally got the carbs tuned well. 56.4mpg last night on the city freeways. There's so much power from the ignition I really can't get the bike to idle under about 1,600rpm once it's warm. Final jetting is 47.5 pilot, 147.5 main, Heiden needles in 2nd slot.
If your bike is fouling plugs, it's not the stock spec plug at fault, there's a problem with your bike. I've never fouled a normal NGK in my 650 or any of my 4 strokes, 2 strokes yes, but never in a 4 stroke.
high idle has nothing to do with "power from the ignition"....air leak or advance problems or carbs out of sync
I'm not changing anything because my idle is 400rpm fast.
EK
