Metal
XS650 Custom shop
Hi y'all.
So last night I set my cam chain tension and it did need adjustment. I then adjusted my valves and then I went to do my point gaps.
When I went to set up my points I couldn't get the points to open in side the marks either side of the F. They are new points. I went to set the gap between .012" and .016" but with that gap the points wouldn't open until way past TDC. So in the hope to get the bike to even run I turned the crank to the fire position and set the gap to crack open at the right time disregarding what the gap should be at the full open position. I have no more adjustment left in my points plate making it impossible to adjust the timing.
This is my first time setting points and I have a PMA I just installed. I transferred the timing marks from the old rotor. But I feel like things are just not lining up. My only thought is the cam chain has stretched or skipped a tooth.
I could use some advice.
