Well nuts really wanted these carbs to work out ,thanks for the info.Not exactly. Early bikes had two separate throttle cables and a twist grip that took two cables. So, you'd need to find a '75 or earlier throttle assembly and the original, correct butterfly shaft for the right carb. It would have the threaded outside end to bolt on a cable arm just like the left carb has .....
