Just a
mini update for the moment
Bike starts first kick everytime
so that is a good thing, sadly there is a oil leak coming from LHS side engine case this looks like it involves replacing two oil seals or atleast I hope this will sort it
Still waiting for the headlight mounts
and still waiting for a ton of really small parts like connectors, grips etc..
I removed the front caliper piston and it is corroded even after a good rub down
so looks like a new one will be needed..
So far the bike has cost me about 170 pounds or about $250 US not bad me thinks, I would spend this on a cycle wheel
Things to do::
Flat track or Cafe seat and pad..
Make sure the bike won't burn to dust due to my wiring
New fuel cap and key..
See if I can pick up a set of rear shocks..
The fuel tap is a concern and Im not a fan of Vacuum taps as I have had issue on a few of my Honda V4's so "may" look at getting summin different..
Pod style air filters looking at either K&N or Ramair but will cross this bridge when I start to sort jetting..
Get and fit braided front line, these have gone up a sh1t load over the last year
and no one in the UK offers just one front line for this model so will have to start measuring for a custom line.. I always try and stay away from a 3line setup (Or 2 in this case) if only to help the bleeding process..
Sucks that im working on the bike outside as my normal work space is taken up with another bike, but the sun gods have been fair on me so isnt to bad..
Oh should say im gona try one of the small 12v 0.8ah batterys that have been spoke about on the forum will give a update on how it works (if it does??)
