75XSFLORIDA
Yes the fuse on the green can sense what the rotor get
OK so the fuse should go on the GREEN wire then correct, not the brown wire like somebody said 20 minutes ago??
Unfortunately, as someone else noted , your meter will not read enough Amps to test the rotor. You need one that will read at least 10 ounce. You can pick one up at Lowe’s or Home Depot for about 30 -$40.
Who said?OK so the fuse should go on the GREEN wire then correct, not the brown wire like somebody said 20 minutes ago??
You know sometimes you just have to do things to rule things out. Easiest way to rule out the rotor as the problem would be to put a 10 amp fuse in the brown wire going to the regulator. Do it at the connector going to the regulator so it only protects the reg/rotor.
Who said?
Well..that guy knows what he's talking aboutThis guy right here said BROWN wire. This is why i do my own research as well!!
Doing this test I’m only getting 0.19amps and that is when I’m revving the bike. If I do not rev the bike I get nothing on the meter…. Also, if I do not start the bike and just put the key on like you said, I get nothing on the meter.
Not sure what you are talking about there but we are with the fuse --- experimenting --- the extra use will blow ... if not --- the 20 A will blow again We try to narrow it down
The only short the green wire may detect is the to the brush and the rotor. The brown at that connector would also include the regulator itself. The brown in the headlight bucket a whole bunch of short locations: depends on what ya wanna test for......
I'm just a dumb hilljack, but me, I'd start at the begining of the brown circuit in the headlight bucket (unless I was testing reg. rotor only) and then -progressively - work toward the remaining circuit. Assuming the brown circuit blew the test fuse at all
What if that’s the case should I put the fuse at the brown wire on the regulator side and not the green wire?? Why not test all the components if I’m going to do it. It just looked to me like the green wire makes more sense.
Why cut the wire. Not necessary at allYeah, but I still have to cut the brown wire to put this connector in. I was trying to avoid cutting….should I cut the brown wire right here where my fingers at, or the left side of the picture, the brown wire at the main harness side?
It’s either that or build a jumper harness
? Separating regulator connector 3 wires in between one with the fuse perhaps
No you Jack-A-Loaf. The Brown. You want to divide and concur. If the fuse blows then you know it's in the regulator, rotor or their wiring. If the main blows then you've ruled them out. Now that will not rule out the rectifier.NOT the brown wire….the GREEN wire!
I will bow out of this since you seem more interested in questioning help than actually doing anything.
