lopejd01
I removed my clutch cover to do some polishing and now I'm having trouble with getting the kick starter mechanism back into place. I followed this thread : http://www.xs650.com/forum/showthread.php?t=772
But I'm not sure if It's in right. When the lever is pressed down, are the gears from the kicker and the clutch basket supposed to interlock completely? When I press down on the lever the kicker gear rotates into the gear on the clutch basket but only about 1/4 or 1/2 of each teeth interlock. I tested it by trying to kick the bike and the gears on the clutch basket do turn but It's very hard to kick it. Is this because I don't have the case cover on or could it be because I dont have the clutch cable hooked up- I have the left case cover removed too.
Or is the kicker mechanism just not installed properly?
