Take Warning15
I've got a 75 with BS 38 carbs. I've got a bad intake valve on the right side only. Left side runs and has compression. Looking into the head with the manifold off I can see lots of carbon buildup around the valve.
Two questions:
1. Why might this happen? Running too rich on that side?
2. Thoughts on lapping the valve with the engine in the frame? If I can get to it in the frame, would it be effective enough or should I expect to need a machine shop?
thank you
Two questions:
thank you
