you need to find where the leak is from. base gasket, head, oil delivery pipe, cam chain guide bolts, cam chain adjuster, clutch push rod, shift shaft.. it could go on and on
Do you see the leak/oil on the ground, on the cases, front, back?
Head bolts need retorquing? common
Clutch push rod seal. common
Drive sprocket nut too loose. common
Cam Chain adjuster seal/oring. not as common
Crank seal. not common
Seals on the shocks.
Drain plugs or sump plate.
Too much oil on the chain?
