voelser
Right, while I am sorting the jetting on my new Mikuni’s on my other XS I am also trying to solve a riddle on my chopper XS.
The engine in this was rephased, upgraded to 750cc by Howard Smedley before it was mine. It also has the Mikuni TM34’s, which I am trying to tune, but can’t until I solve the issue in this thread. It runs a Heiden tuning electronic ignition and A pair of XS performance coils (the big green ones).
The issue is that the left hand cylinder spark plug seems to fail every time it’s run once. The engine runs rich (which I am trying to solve by tuning), but the plug doesn’t just foul, it dies. Even after cleaning it won’t spark. This is the parrtern: set of fresh plugs, try to spark them out of the engine. Both give a nice fat spark. Put them in the engine and try to get it running. It is kickstart only, so it sometimes takes a while. When it finally runs, 9 times out of 10 the left cylinder runs cold. When I then test the plugs out of the engine again the left hand plug won’t spark or spark very little. This happens almost every time, with different plugs.
I’m a tad stumped. My first suspect was rich running engine. It does run rich at the moment, but not so mich it should cause this issue. Besides, the right cylinder plug looks the same and does keep running. Other suspct is the plug leads. When thing I did notice when testing out of the engine was that I got zapped, even though I held the plug cap at the back. Could be that the spark escapes? Yet to test new leads (ran out of time and will today). Suspect number three: coils. may swap them round and see. And last maybe the timing is out?
Open to other suggestions!
