wwitten
I swear this bike is going to be the death of me...one way or the other.
OK with all of your help have gotten through problem after problem and was actually riding for a couple of day, but was concerned when I slapped the battery charger on just to top her off and noticed the battery had low voltage and didn't seem to be re-charging enough.
Checked the battery while bike was running and didn't see any voltage increase while running at any RPM level. Went to the tech section read the info, pulled out the manuals and checked the alternator, regulator and rectifier. All tested within limits but the rectifier concerned me with the amount of corrosion and the red lead at the connector seemed like it might have fried a little at some time in the past. Cleaned everything up, retested, bike started up, checked voltage at battery and charging system seems like it now was up and running. Due to weather bike sat for a few days, but I checked battery and there was only minimal voltage drop. Weather turned good, so I tried to start her up, but no go. Finally checked the plugs and found little if no spark. By this time battery was getting weak so I slapped on the battery charger and within a few minutes, cloud of smoke arose from the old girl. Pulled charger and investigated. The ground wire from the rectifier fried from the rectifier all the way to were it joins the other grounds in the wiring harness under the tank near the coils.
So OK strip the wiring harness replace the bad wire, pull the rectifier, and build a new rectifier using the Radio Shack method discussed in the posts here. Just installed the mod and still little or no spark to plugs.....Guessing somehow I fried my coils? Will check later and see how to diagnosis, but any other thoughts
