I have Mike's new worm and the differences between the holes as far as pull goes it's hardley noticable, now the difference in clutch action was very noticable. Use the inner hole It works the clutch better.
Ride the bike alot and your hand and arm will get stronger.
If your current worm is very worn or cracked you will find the new worm helps a lot.
My 75 cltuch was terrible hard and a new cable helped but not much. I read about how the plastic part of the worm can crack and make the clutch hard to use. I replaced the worm and couldn't believe how well the clutch worked.
A new cable and worm with plenty of good lube and even with the other clutch work, mostly heavy springs, I can pull the lever with two fingers.
