I have recently purchased a 1980 xs650. the frame and id number on the sticker is 2fo-214962. Now judging by the charts and the fact that it has the gas tank with the offset locking gas cap and the side covers mounted by rubber grommets I believe the bike is a "special". can someone please confirm this? Thank you very much from a new xs rider!
Hi tfusc and welcome,
that's what the chart sez for that ID # but to be sure,
here are some visual markers for 1980 & later Specials:-
Electronic ignition.
(note:- the bike kept it's points & mechanical advance covers but there's nothing in them.)
Grab rail is an aluminum casting, not chromed steel tube.
Tail light is attached to the grab rail rather than to the rear fender.
Seat is lift off, not hinged to open.
Side panels are plastic, not steel.
Gas tank has offset cap and reduced (3 USG) capacity.
1980 ONLY has a disk rear brake, 1981 & later reverted to drum rear.
US models usually had megaspoke wire wheels, Canadian models usually had 7-spoke cast wheels.
Specials came with seriously ugly rototiller handlebars that hopefully a PO has swapped out already.
