QWERTYMage
Hey, y'all.
The bike: XS650B
Lowering kit: 2 inches HBB spacers
The Springs: Brand new Mikes XS Progressive springs cut to sit flush with the uncompressed fork tubes (wheel off the ground) to offer slightly stiffer ride and give a bit of preload.
The Oil: Motul 15w @ 175ml.
When I fill both legs, the forks are so stiff my 200lb ass can't compress them.
When I drained both legs, they move freely.
As an experiment, I filled one leg w/ oil and tested it. It compresses as expected the first time, but get stiffer each time I compress them until they won't compress...
Shorter springs don't seem like the answer (as we know they compress). Tubes are straight. The buildup of pressure leads me to believe that the spacer holes aren't lined up, but they were when I dropped the internals in the forks.
Any ideas? Thinner oil? Sounds normal?
Thanks for the help.
Attached is an image of my fork range without oil:
Forks are uncompressed. Yellow is with bike on the ground, Orange is with my weight on the bars...
The bike: XS650B
