LuckyLeprechaun
I've been reading over the forum lately about weight reduction. Many people mention using a different, thinner rotor, usually 5mm, to reduce weight. My question is, since the stock rotors are 7mm thick, couldn't you just cut or machine them down to 5mm?
While it may not be the best weight savings, a rough estimate of .7 pounds per mm shaved. It would however eliminate the need for buying different rotors, making custom spacers, mounting brackets, etc. You could also pair this with cross-drilling to reduce weight even more.
This isn't necessarily something I'm interested in trying, but I was just curious as to if it were feasible.
For reference, I have 34mm forks with a 2 piece rotor.
