1. Having trouble logging in? Try closing your browser and re-opening it. If that doesn't work, try a different browser or device. The site will be updated soon to resolve these browser issues.
    Dismiss Notice
  2. Dismiss Notice
Mannulus Mechanica (build thread)
Discussion in 'The Garage' started by RustiePyles, Oct 28, 2020.
Tags:
  1. RustiePyles
    RustiePyles Semper Fortis XS650.com Supporter Top Contributor
    Just getting started on this bobber build, got ahold of frame (someone else welded the TC Bros HT on it) and a couple of motors I'm going to be building a bobber out of. Just picked up some wheels from Jim (big thanks) today so its officially a motorcycle and not just random piles of parts in my garage now. Machine also sent me an aluminum front rim ( also big thanks) that will get re-spoked and cleaned and eventually live on the front end. Lots more to come! xsframe.jpg xsframe2 (2).jpg tx650a.jpg tx650a2.jpg
    Adamc, LanzSilva, Raymond and 7 others like this.
  2. member28833
    member28833 Race the wind Top Contributor
    Might as well give us a peek at the DT175 too :)
    Adamc, gggGary, halfmile and 2 others like this.
  3. Jim
    ... and I apologized for my garage... :laughing:
    Ahem.... jus' kiddin'. Looking forward to following your build. You gonna hot rod the engine or just a stock top end refresh?
    Adamc and gggGary like this.
  4. RustiePyles
    I think you can see the majority of the DT in those pics, it’s kinda spread out all over right now.
  5. RustiePyles
    yeah I’m kinda out of room at this point organization went out the window a few years ago...
    I’m not really sure about the motor yet, mostly depends on what they look like when I open em ups if I gotta spend a bunch of money just to get em going I might as well do it with go fast parts. If not then it will most likely just get a Hoos cam, ports cleaned up, and valves lapped, rings, and gaskets.
  6. Jim
    If they need it, I made a little fixture for the Atlas to regrind valves.
    Adamc, Raymond, halfmile and 2 others like this.
  7. Jim
    Cruisinimage is your best bet for pistons and rings.... both standard and big bore. Lotsa' people 'round these pars use 'em. Haven't heard a bad word about 'em yet. And they're nicely priced. Look for ARS seals. They're the same folk that made the OEM's... Japanese instead of you know who. :whistle:
  8. RustiePyles
    Jim, that’s a nice tool post grinder. Have you got a seat cutter set as well?
    Adamc, gggGary and halfmile like this.
  9. Jim
    I bought most of the parts I need to make a seat cutter, just haven't got around to putting it together. Lemme' know when you get close. Maybe that will motivate me... :rolleyes:
    Adamc, halfmile and RustiePyles like this.
  10. halfmile
    halfmile XS Builder XS650.com Supporter Top Contributor
    1,527
    5,611
    513
    kansas
    If your needing anything for your DT175 I`ve got a lot of NOS and OEM parts.:thumbsup:
    Adamc, RustiePyles, gggGary and 3 others like this.
  11. RustiePyles
    PM Sent
    Jim likes this.
  12. RustiePyles
    Got the wheels from @Jim on, looks a little more like a bike now. FA6DDF2B-6E05-45FF-8C6E-F1E261E7C8BF.jpeg 240295A8-62AA-42C6-9FA3-6F6164B88E58.jpeg
    Adamc, LanzSilva, Raymond and 2 others like this.
  13. Jim
    Nice. I was just thinkin' I shoulda let you borrow my dummy motor to check the engine mounts. Since the PO did the hardtail, I'd double check 'em before getting to far down the road.
    Adamc, Raymond, lakeview and 2 others like this.
  14. RustiePyles
    As far as I can tell PO was not a great welder, but it would appear that they did line everything up fairly well. Looks pretty straight. Nothing that can’t be fixed with a grinder. I’ve got a pretty sizable jib crane so dropping a motor in isn’t that big a deal. I’ve got a little welding to do before drop one of my motors in.
    Adamc, Raymond and Jim like this.
  15. RustiePyles
    Ok, Finally got it up on the lift. Got some rear wheels spacers turned on the lathe. chop.jpg space1.jpg space.jpg chop.jpg space1.jpg
    Adamc, LanzSilva, Jim and 1 other person like this.
  16. RustiePyles
    Started working on making a set of mid-mount peg brackets using an old set of sporty passenger pegs I had laying around. peg.jpg peg1.jpg
  17. gggGary
    gggGary On the road of life I'm a speed bump. XS650.com Supporter Top Contributor
    Looks like excellent work!
    Rusty; I'll pile on, heed Jim's test fit a motor sooner than later advice. See if ALL the mount bolts will go in. Will beat having tufts of pulled hair on the shop floor later.
    Adamc, buzzword, RustiePyles and 2 others like this.
  18. RustiePyles
    Yeah, I intend to test fit a motor as soon as I get the peg mounts welded on because I need to be able to flip the frame over to weld on the bottom. I also need to come up with some motor mounts. The bottom and rear bottom mount bolts will just be 10mm rod threaded on the ends in the lathe but I need to get a front motor mount assembly and set of upper rear plates, wont be running a head stay. Strangely enough I actually have a spare head stay:doh:
    Adamc, Jim and gggGary like this.
  19. Jim
    Don't that just figure.... :rolleyes:
    Thought I had extra mounts... but no joy. Try @halfmile over in Topeka. He's prolly got a bathtub full. @DanielBlack over in St Looy had some for sale earlier this yr. Give him a pm?
    Adamc and RustiePyles like this.
  20. DanielBlack
    DanielBlack XS650 Junkie
    Negative here on the motor mounts. Jim and Grey grabbed the two I had.
    Adamc, Jim and RustiePyles like this.
Share This Page
