Yes, those 3 mounting points give a nice, solid pipe mount, but using the higher hole on the bottom will jack the rear end of the pipe up more. If you can make that other higher hole work, it may give you the increased muffler upsweep you desire.
While the bike was "down" waiting for a part, I got to play with a light I had been eyeballing for a while. I was doing some late night Amazon surfing and found a bracket which I believed could be made to fit this light with very very minor modifications. Well I was right. 5 minutes of hand-filing some holes and it was a fit.
A license plate bracket made from 1/4" sheet aluminum, cut directly after the license plate round out the experiment.
This thing is BRIGHT, like holy sh!t bright and the brake light is idiotically bright. It's perfect. I also has a DOT stamp which is a fun bonus.
This is the only one I have of it lit up. You may notice it’s not fully mounted yet. Pic doesn’t really do it justice as far as brightness. It has either 6 or8 LED’s underneath dedicated to the plate also which is sweet.
Fun fact: It’s mounted on the stock taillight rubber base with the stock taillight bolts.
Ehh ... no tail light on that 78' I'm going to look at.... or rear fender... or front fender... or tank .. or seat... but hey, the frame, front end, front brake, engine and those nice aluminum spoked wheels are there, and that's what I call a good start!
