Adrain, I have a suggestion. make certain you combustion chambers are healthy prior to trying to tune the bike. Is the engine a virgin? Any recent engine work? Try these tests if you are not 100 % sure of the cylinders condition; remove the spark plugs and do a cylinder leak down test. Bring each cylinder up on its compression stroke to top dead center. The get the transmission in its highest gear. apply 150 psi to the cylinder and listen for leaks from the intake, exhaust, and crankcase breather. Get set up and do this with the engine hot. Then after that test, rotate the engine and lower the piston to its center stroke point and do the test again. Holding the bike in hi gear helps keep it still. The pressure in the cylinder is trying to rotate the engine. you may need help holding the bike from rolling forward with the pressure in the cylinder. before you make any judgements on the carbs you need to be sure the cylinders are healthy. I have the same carbs just installed and they run awesome. Not rich at all. But I just did a valve job and new rings. Another quick and dirty way to test is set the engine at 1200 rpm. pull one plug wire off. What is the RPM now? My engine runs at about 750 rpm on each cylinder. Also, starting the bike cold, measure the exhaust temp from each cylinder cold and as it warms up. Write it down every 30 seconds while the enrichners are pulled up. Warm it a bit, then take the bike for a nice light short loaded run with out much stopping. measure the temp again of the exhaust and temp of the pipes close to the head. determing if both cylinders are contributing equally. THEN you can start talking jet size. Also, what spark plugs are you using? Do you have the standard origional ignition system?
