Mine were only sometimes sticking a couple of mm above where they should seat. Depending on how quickly you close the throttle, the slides might not snap all the way shut and the vacuum from the engine pulling on the slides can also help make them stick just ever so slightly. The only way I knew they were doing that is by running the engine in my garage without filters and when the idle would hang, I would try to physically push the slide down with a screwdriver. If I saw them move at all, I knew they were hanging up just slightly. This could be from friction, a weak spring, cable that's not lubed, or friction in the throttle itself.
