Recently had a tach cable break. I replaced it with one of Mikes cables (received from a private sale).
The tach would work ok for a short time then the needle would start an erratic bumping.
Removing at the base coupling I could move it back up and it would engage the tach drive again and then fall back down after a while. So I pulled another oem cable to compare.
Flushed at the top end Mikes is a 1/4 inch shorter. You are looking at the broke cable, Mikes and the intact oem.
I don't have a cable stretcher so I needed a way to block/shim Mikes so it would stay in the tach.
A quick look round I found some left over brake line. This may work.
The OD is close and the ID a snug fit over the cable. A 3/8" spacer cut and fitted.
Back in business. Tomorrow I'll run it some to see if it will stay in place.
