pamcopete
Ride.Enjoy.Life is Simple
A friend of mine asked me to help him with the installation of MikesXS 2 into 1 exhaust system Part #07-0767 so i decided to make a couple of videos and pics in case someone else wanted to see how it's done.
Here is the kit and the muffler, XS Performance Reverse Cone Megaphone Muffler Part #07-0112 the header on the left goes on the left side and the header on the right goes on the right:
Start by replacing the gaskets.
Then, install the headers:
Snug up the header nuts on the studs but do not tighten completely. You want to leave some movement for the final adjustment of the collector to the head pipes.
Next, take a look at the collector:
The little welded on brace goes to the inside toward the frame. The clamp goes on the lower outside.
Attach the collector, but just leave it loose at this time. Do not tighten the clamp.
Now, attach the muffler.
This installation is on a 1983 Special and we found that the long straight hanger that comes with the muffler does not work with this frame. Instead, we used a short "Z" shaped hanger from MikesXS, part number 07-0201.
We also extended the piece with the threaded holes that now comes with the muffler beyond the end of the bracket, then installed another bolt to hold it in place.
Again, do not tighten the muffler clamp or hanger bolts. Leave everything loose so you can adjust the whole assembly to provide clearance for the brake lever. When adjusting everything for clearance for the brake lever, be careful that you do not end up with the headers tilted from being perpendicular to the head. Just take your time and move things around for the results as shown. When we finished, there was no twisting or bending and the headers were perpendicular to the heads and there was adequate clearance for the brake lever. When you do tighten the header nuts, use a torque wrench. The nuts are only torqued to 10 Ft. Pounds despite their size due to the expansion when they get hot.
Here is a picture of the collector after final assembly and with every thing tightened up. Notice that the bottom of the collector is angled to wards the bike and that there is adequate clearance with the brake lever.
