Well, 10 years later, here's my 2 cents. Yes. Very good. Just bolt-on. You do need to check the ring gaps though. I had to slightly grind 3 of the rings. I mildly ported the head before installing the kit and had the valves done at a local speed shop. The cam is stock from a 75, so it's the mild cam. I didn't built it for all out balls, I built it for reliability and longevity. With stock BS 38 carbs, I experimented by changing all the jets, but finally settled on just one step up on the main jet. I use the stock air boxes with foam filters, also.
My 72 was very tired with about 65K miles, so the difference was night and day. Loads of torque throughout the entire rpm range. Don't have to downshift much, even for passing. The larger fins help with cooling and make the engine look beefier.
I have about 12K miles on the kit and it is still running strong. Yes, it's worth it.
