Same issues.. today... 79' Special.. toss'd the points... installed electronic ignition... made brackets to support the coils, other related bits.. soldered, heat shrunk connections.... also tossed the old rectifier and regulator.... installed the combined unit from Mike's... soldered the 3 white wires, red wire, blk wire.. heat shrunk... install in the accompanying white block.. then the other lead from the unit.. grn wire and brown wire.... NO blk wire.... on the stock system there is a blk wire.. I assumed it wasn't needed and wired through the new unit. Again.. grn and brown wire soldered, heat shrunk..insert in the new white block. There were no directions with this package.
The moment of truth.... key on....hit the starter...fired straight away.... checked with a time'n light...need'd a slight tweak .. then right on the mark.. runs great.... (we also went thru the carbs)
Checked the charge'n system.... battery voltage only.... no charge'n. We know the old system worked... even re-installed it to verify the system worked, 13.9-14.2 volts... did the " slap test ".. pass'd... Then we installed the new Mike's unit again.. and still no charge'n.
