<rant>
Finally got my tank back from the local welder/bike shop after waiting two weeks. Work was not done how I wanted though. I'm actually pretty dissatisfied. Just a reminder that I should just do everything myself. Instead of the two 1/8" petcocks that the guy talked me into I got the single HD 22mm petcock that hits the top of the carb when the tank is mounted. The filler was welded on about 1/2" to one side after I told him that my X needed to be centered. And the filler plate over the old filler wasn't really that nice. I'm sure I could have done this quality work myself and the reason I wanted a pro to do it. Live and learn. I was only out $65 for the work. That's about all it was worth anyway.
</rant>
Anyway, I got the tank mounted (had some issues with that too), new forks are installed (they are sweet) and went out for a short ride. My fender almost fell off, my clutch failed, and my fuel hose split in about 10 minutes.
Replaced the fuel hose, fixed my fender, put my old cable clutch back on, and went for another ride. Everything stayed together this time.
I also found out that shifting without the clutch works a lot better. Usually for downshifting I pull the clutch and try to downshift and I just can't get it in. This time I just downshifted without the clutch and it went right in easy as pie.
I started experimenting with shifting not using the clutch. It shifted great. Getting it into neutral while stopped is still not working, so I just have to remember to do it when I'm still going over 10mph.
I have a brand new clutch worm gear installed now so I'll fool with adjusting and see if I can dial it in. Practically everything is new now except the gears in the transmission and the clutch basket.
I'll post up some photos when I get the paint on it in the next few weeks.
