NorazDad
NorazDad
I thought after being a lurker for the last year, I would finally get around to introducing myself and my bike. I bought the bike with 18K miles on it and it ran great from the get go. I changed tires, Pirelli in the back and an old school Dunlop in the front, 17/34 sprockets, O ring chain, new brake pads and rebuilt the Master cylinder. I put 1K+ miles on it before I got into the winter break down.
I needed to fix a spring on the wet side of the case and replace the oil seal on the tach. Checked the clutch pads and spent hours trying to get the case back on without ruining the gasket while getting the kick starter spring to catch. Then on to the left side to replace the clutch push rod and seal. Took two tries to get the seal right...the dremel trick worked great for smoothening out the rough edges.
Oh, and I removed the starter motor and solenoid and put in the hole block from Mikes.
So, while reading up on upgrades and with a few extra bucks in my pocket, I decided to order a HHB PMA...only to find that I would have to go with a different ignition system because the TCI would be eliminated with the PMA...oh well.
So I ordered the Ultimate Pamco from Mikes with the EAdv and here is where things get interesting...
I failed to mention that my turn indicators did not work and I read everything I could on that topic and couldn't leave it alone. In a pm, XSLeo said that I would have to learn the whole electrical system to really answer my questions...so I did. While tracing the wires for the indicators I started to unplug stuff...I've been doing that since I was a kid. I labeled everything I could and then found Jayel's wonderful wiring map and used it to identify everything I couldn't figure out. Then I started reading. I loved Jayel's posts about being the light checker eliminator, et al. That really got me started on taking out all of the unnecessary electrical elements.
I'm going to start a new post on the whole electrical process.
By the way...you guys are great, unless you get snarky, but he technical help has been wonderful and I thank you.
Rob end part one. well maybe not
The tear out...
I proceeded to tear out all of the relays and strip the harness all the way to the junction where the harness splits to go to the hand controls and the bucket.
I found a number of rewires and splices that were miss color coded and proceeded to clean those up. I rewired my four blade fuse block...the old wires made no sense as to where they were going. With the starter gone, I knew I could start cutting.
Gotta go for now, will follow up in a few.
now end part one.
The tear out...
now end part one.
