darynar1016
I am in the process of getting my bike together and everything is back in place after a complete teardown this winter but it won't kick over and start.
'79 engine.
Running a PMA, Pamco electronic ignition, and stock spring advance.
Mikuni vm34 jetted by 650central. 180 MJ, 25 PJ, and needle clip halfway. The air screws are 1.5 turned out and the idle sync is set with a 3/16 drill bit.
I have cleaned the carbs out and they get fuel.
For exhaust I have MikesXS straight pipes with baffles.
I have checked and adjusted the cam chain tensioner and lapped the valves accordingly.
I have looked through pamco petes instructions for testing my coil and it seems to be ok.
I am also running iridium plugs that have been gapped.
Last year I ran the bike on a mini .08ah battery and it ran great but the battery is dead now and I want to run a capacitor.
My problem is when I go to kickstart the bike and it won't start. If I run the choke and kick it then it will seem like it has a little life and it could start but it quickly dies. After that regardless of the choke on or off I cannot get much from it. It seems like it doesn't get spark after that first kick until I tinker with the carbs a bit and then once in a while I can get some noise from it but nothing that resembles staying started.
I have checked my wiring and its as simple as it gets and it should be fine as well. I used a diagram from this site and it worked fine all last year when I ran the bike with the little battery.
I have tinkered with my air screws and idle mixtures but I cannot for the life of me figure out my problem.
I'd appreciate any help anyone can provide. I'm just lost, tired, and need a new set of eyes on this issues.
Thanks.
Daryn.
'79 engine.
Thanks.
Daryn.
