Just a quick update....my carbs are possessed. Time to throw more money at them!
Anyway, I was only able to get a decent idle and eliminate pops with the carbs set up with 125 mains and 27.5 pilots and the needle dropped one slot and mix screws right at 1.5 turns, just like the very first day when I posted this thread, except this time I swapped the new float valves with the old Mikunis ones I replaced thinking the new ones could have possibly been leaking, and my floats are properly set at 24mm....
This setup has given me about 100 miles of decent performance (when I say decent, I mean no backfiring, no stalling, etc., but a pretty weak midrange).
Bringing the needle back to the factory #3 position, which would richen the midrange, seems to lean out the pilot circuit? What gives? The bike sputters and pops out the left cylinder and shoots flames on decel; it also will not hold an idle and stall when hot....which would indicate lean, correct? Only when I put the needle down a slot does it start acting right.
However the performance is inconsistent at best. Yesterday was our first day of cold weather in Dallas (48*), and you could really feel the lack of testes in the midrange when opening it up, it simply feels like there should be more. Plus, the idle would run high once hot....I could get it to notch down a bit when blipping the throttle. Strangely, bike has backfired out the right carb 2 times over the miles I've put on the bike.
I went ahead and ordered genuine Mikuni 130 mains and 27.5 pilots to replace the ones that came in the Mikes rebuild kit. I'm also going to go ahead and pull the carbs back down to the screws to see if I can't find any foreign object debris. With the 130 mains I'll leave the needles alone.
The top end is leaking a bit of oil from valve seals, but after running the engine a few miles since I finished my build it seems to have gotten a little better. Since the season is pretty much over for riding I'll pull the engine and send the head to Hoos, but not before I try out the new jets next week.
EDIT: I was browsing the carb guide, and this is an interesting bit I am experiencing with my carbs:
"Too small of a pilot can be indicated by an idle that "hangs" after blipping the throttle or
by having the motor be slow to return to idle after running at higher speeds. Once again,
mix screw settings may help here."
This was happening after my cold weather run yesterday, would a 27.5 pilot jet still be too small for my application?
