1. Dismiss Notice
    Dismiss Notice
New by electric question
Discussion in 'The Garage' started by koyuga, Feb 1, 2019.
  1. koyuga
    koyuga XS650 Enthusiast
    What is the most basic wiring system to run an engine with.
    Original charging system.
    Starter motor
    Battery
    Dual coils
    I have all of the above, guess I'm gonna need a combined reg rectifier.
    Do I need an ignition unit??
    As I said I'm a newby and i just wanna try my hand at getting an old wreck running.
    Cheers
  2. Superjet
    Superjet XS650 Guru Top Contributor
    I think this should work for you. No need to do combined and you can build a DIY regulator / rectifier for cheap. Look it up using a VR115 regulator and 3 phase rectifier.
    Stardust83 and gggGary like this.
  3. koyuga
    Many thx
    gggGary likes this.
  4. 5twins
    19,996
    11,878
    813
    The regulator you need will depend on which version of stock charging system you have. On early systems up to '79, the regulator fed power to the outer brush. On the later '80-'83 systems, the regulator fed a ground to the outer brush. The Fiat regulator is the ground switching type for use on the later systems. For the early systems you need a power switching regulator. Many use the VR115 or one of it's equivalents.
    You can use the later ground switching type regulator on an early system if you change some of the brush mounting screws to nylon and re-wire the brushes. If you're starting from scratch and have to buy a regulator anyway, I don't see the point to this. Just buy the correct type of regulator to begin with.
    Stardust83 likes this.
  5. Superjet
    Sorry 5t. I just updated my post. I know I know we just went thru all that stuff.....lol
  6. 5twins
    19,996
    11,878
    813
    Yes, it is confusing, lol. But I think these charging systems are pretty easy to understand once you learn about them, and I love the fact that we can use low cost, dependable automotive regulators.
    Superjet likes this.
  7. 650Skull
    650Skull SSSSSSSSSlither Top Contributor
    If you do buy a 70-79 points B type Combined Reg/Rect, then make sure the Unit has 2 Separate Connectors attached to the Combined Reg/Rect so it will connect to the 70-79 loom......Sellers often have the wrong models in the heading
    For some reason this thread opens on post #37..........NOTE; go back to post #33
    A good thread on the 70-79 Points model Regulator and rectifier conversion to Automotive regulator and 3 Phase Rectifier........ http://www.xs650.com/threads/how-do-i-test-my-stock-alternator.53079/page-2#post-564584 ..... Post #33 Has all the information needed for this conversion
  8. wildav
    wildav XS650 Enthusiast
    visual aid : came off my 79 sf. don't remember why I removed connectors IMG_2257.JPG
    gggGary likes this.
  9. 650Skull
    This is the 70-79 points model Combined Reg/Rect that MikesXS sells now
    NOTE; That's an old Obsolete one mikesXS used to sell and the wire colours are completely different to the one he sells now.........
  10. wildav
    right you are , I bought this one in 2006 or 7. I remember there was a little confusion installing because of the colors. A really amateur drawing showing connections to existing wiring came with it.
  11. koyuga
    thx for all the replies. Cheers
Share This Page
