Carbs,
www.amckayltd.com/carbguide/pdf
So the engine turns over by kicking but won't start, right
Pull out both plugs, leave the key switch in the off position. Now with a finger plugging one plug hole, kick the bike over. Do both sides.
Do both sides blow your finger out of the plug hole with a good fast kick?
Get a repair manual, I did mention this didn't I. Free download from biker.net
Get it, read it. Start with a basic tune up.
Check cam chain tension
Check valve clearance
Check points gaps, two sets of points, two gaps
Check points timing
Once you do these things, IN ORDER then use the carb guide to tear down and clean the carbs.
Don't buy any kits, most have the wrong parts in them except the float bowl gasket and float valves, jets and needles are usaully wrong.
Your gaskets are probably ok to reuse if your careful on tear down.
The spray can carb cleaner works well. A can or two of compressed air will help.
While you have the carbs apart, wqrite down the numbers written on the pilot jets, main jets, needle jets and the needle.
