So after half assing my build before, cutting corners, I kicked myself in the nuts and got my shit together. I'm sparing no expense with the build and will be replacing every nut and bolt I feel needs to be replaced. I'm starting with the front end getting redone, and working my way back. I will be moving next April, so no engine building for now, simply trying to get a 100% done roller. So far i purchased the number plate, mounts, graphics, lights, bars, handguards and tire. Sending my forks out to hugh to have the forks rebuilt and the legs shaved. The only mounts will be for one disc as i plan on running a brembo. New rim and spokes will be ordered as thats getting done. Then i will be sending parts to powder coat. Everything marked in white on the bike will be removed. Also started planning out the tail section. The top hole by the hoop will be for an sv650 tail light with integrated turn signals, the bottom holes are simply for looks/airflow. Here are some photos, I hope you enjoy. Also, if you have any tips or suggestions let me know!
