NoValidTitle
So the guy might even be on this forum but do you guys think $800 is worth it for this?
This is what I've been told about it so far. Not sure it's worth it. Having no real knowledge of the motor makes me a bit suspicious.
As best that I can tell most parts are there. I swapped this for another
bike I had and it came in boxes. I have the hardtail tacked into place. The
wiring harness is there but it is missing the ignition switch and voltage
regulator. The hardtail is mfg by TC BRos and seems to be a quality piece.
The top end of the motor has been disassembled and the motor has been
cleaned with the side cases painted black. The carbs are there and most
likely will need to be rebuilt. It looks to have a fresh rebore/Hone and has
a gasket kit included with it. I have two fuel tanks for it as well as a set
of wire wheeels(fair condition) and a set of front forks.If you know this
type of bike you understand the popularity and the abundance of parts that
are available(both stock and High performance). Check out Mikes XS on line
to see what I mean.As I stated it is a serious project needing assembly.
