Very frustrated. Got them set don't hey don't leak, installed. Very hard starting, choke full on. Mixture screws at 1.5 turns from closed.idles only, does if I give throttle. Adjust out to 1.75 turns, no better. Adjust to 1.25 turns, no better. Intermittent "Pop" at idle. Pull choke off after 2 minutes of mixture adjust, motor does. Left carb leaking.
I adjusted the floats so they only visibly move, I'm talking no measurable amount of movement. Blow test so that if I touch the float it stops. Flow is restricted when in open position, that's how little movement is allowed.
How am I the only one with this issue? What am I screwing up?
