TeeCat
One-Mik Wonder
Hey, all...
I have a non-MC mechanical question. I thought I'd ask here because of the breadth of mechanical knowledge and experience, and this issue may not be at all uncommon among you.
I have an '02 Xterra that I love. About 104,000 miles, no mods. Recently, it was becoming increasingly obvious that the muffler and adjoining pipes (original) needed attention, so I had OEM replacements installed, basically from the cats rearward. I had the work done at a local Midas, where the work and customer care has been excellent.
Right after that - the same day on the way home - I got a Service Engine Soon (SES) light that I'd never had before. The truck would not go beyond 2500 rpm, so I went back, and it was discovered that the tech had simply forgotten to plug in the mass air sensor after the courtesy check. No biggie.
I'm still getting the light intermittently, though, and I used Advance Auto's scanner the other day. It shows 4 codes - actually 2, but each one twice. One's for the knock sensor and the other's for the O2 sensor on the right bank. The knock sensor is below the intake manifold and I'm not even going there. The O2 sensor is easily accessible to someone with a lift, stands, etc., I suppose.
So, basically, I find this timing interesting since it's coincident with a new exhaust. Could I have a bad right bank sensor, or could the work and the new exhaust envoronment simply have "confused" or "upset" the computer? The truck seems to be running as well as ever - quiet too - and I can't throw any more money at it right now.
Thoughts appreciated!
TC
TC
