Fissure
XS650 New Member
Im not sure if someone has solved this problem before..
I recently added 4 led blinkers to my 79 special, wiring is pretty stock minus the starter, ign solenoid , safety relay, and kill switch. first thing i learned is the flashers all come on at once.. so i rectified that by pulling the indicator bulb in the center cluster. now they just stay solid, so i bought a load equalizer and installed that. Still no blink, tried the flasher relay from a working bike and still no blink. both relays work in the other bike so its not that. I suspect a different voltage relay or maybe just stick an 1157 in there somewhere to add draw? pretty stumped here. Am I just overlooking something real obvious, like rectify the circuit with diodes and put the indicator bulb back?
