Well, I started this project by rebuilding the carbs. They were so badly seized with old gas gunk that I had to boil them to get the slides loose... the kick start cover was off when I get it and the spring was displaced deductive logic and common sense got this back into its proper sitting position.
Now the kickstarter is engaging but absolutely nothing is happening when I kick it over... pulled the plug on the right side and no air is pushing out when I kick. Given the shape that the carbs were in and the way new oil snelled of terpintine when I drained it to fix the kick starter. Im guessing really old gas has fouled and seized more than just the carbs...
Just wondering where I should go next.. points? Cylinder heads? What's the next logical step? Bike is a 79 with 3600 miles so you know it has been sitting ssince the 90s at least...
Just wondering what you guys would do before deciding to pull the engine?
