In your previous post, I understood you to say that you turned up the idle, meaning that it is idling faster than 1200 RPM. If it is idling at, say, 1300 RPM then some of the available advance has come into play, but you would have adjusted (retarded) the timing to the timing mark, so that advance is not available to reach full advance.
So, rather than go back and forth on the issue, just humor me and try setting the idle advance at 1,000 RPM which would ensure that you are not using any advance at idle, leaving all of the available advance to reach full advance at 3200 RPM.
