Bentwrench
Okay, so I picked up a 1978 model XS650 about two weeks ago. It was running (rough, I've been told) last fall, and then was stored under a tarp outside all winter, due to too-many-project syndrome on the part of the former owner. The bike is complete, and looks in pretty good shape, but so far, after much lurking and usage of the search function, I can't get spark. Here's what I've done:
1. Cleaned the carbs. Not an electrical troubleshooting step, I know, but they needed it, so I did it. Twice.
2. Replaced the battery. The old one had frozen solid, and the cells were obviously low. Couldn't hold a charge. So I ordered a new one from Mike's XS, and charged it up with my AGM-safe trickle charger.
3. Cleaned and regapped the points. Great write-up on this site, thank you.
4. Tested the engine kill switch. It's working as required.
5. Checked all my fuses. One of the POs replaced the fuse block with individual fuses - they all check out, and as I said, the bike was running with the replacement fuses last fall (as in, the wiring to replace the block is not currently under suspicion.)
6. Checked the plug wires and boots. They work and have resistance as required.
7. Coils... well, I've tried to test them. They seem to be working as required, as in either they're both blown, or they're both fine. I have to admit, the instructions I've found here to check coils are a little confusing. As far as I can tell, there are really only three connections to them - two small wires that attach to the harness, and the plug wire. There is infinite resistance between the two small wires, and I'd have to recheck, but there's some resistance (but not infinite) between the plug boots and the small wires.
And that's it. I'm not sure where to go next. With an engine not running (although my started does work) I'm not sure what's the next likely culprit. I'm willing to bet it will be a common connection for both cylinders, as the bike was running less than a year ago.
Any suggestions? Please help. The suggestion that gets my bike running wins at least a pint of beer.
