Take the baffles out reduce the rear sporcket 2 to 3 teeth red line before changing gear check plugs for right fueling make sure valve and tesioner and timing is right .. and get the advancer doing its job then report back from looking at the vid
This Question "Not getting top speed " is a tricky idea it depends on many factors firstly lets asume your engine is perfect.
so what would be the speed of a perfect engine say 90 to 120mph OK!
next question where are you testing the so called top speed at sea level or up a mountain is the road level or up hill ,,, these bikes are carborated machines...so fuel is a factor too
Power to Weight is the next issue then tyres ...what about throttle response then gearing or even styling which will effect airflow over the bike what they call AIRO in the race world.
Man has tried to squeeze as much power from and engine as possible to go as fast as they can with that perticular engine.
so the real question is" How fast can i get this engine to go". and to do that everything has to be spot on
Good Luck i have lived and am living in that world it is an expensive endevour
All the best Funky
