I have the right side case cover off to replace clutch springs and replace the steel spacer at the base of the tach drive shaft. I inspected the driveshaft and noticed an odd finish on the end of the shaft. Looks like fine grooves or serrations in the shaft. Is this normal? I was thinking maybe it’s to aid in oil distribution around the shaft end in a blind hole?
