If you want a show quality appearance, with dry gasket edges showing, and the mating surfaces are really flat and clean, you could assemble the gaskets dry, like what was done at the factory.
I put a thin coating of grease on both sides of my gaskets so they won't stick during servicing, and can be re-used. Factory method is to install gaskets dry, but some of us gearheads hate ruining and scraping gaskets everytime a cover is pulled, so this is just a convenience trick.
The side cover gasket was removed to redo the #4 starter gear, and I heard it is good to soak the gasket in oil before installation or put a thin film of grease on both sides before installation, or should I keep it dry?
