Just wondering if i'm on the right track here. my 78' had a very small oil drip leak. i notice the starter bolts were loose and i tighten them up now there is a big leak . it went from a drip or two to a small puddle. i'm thinking it is the starter rubber gasket where the gear fits inside. the leak seems to be coming from in between the starter and the case running down the starter to the ground. the motor was completely rebuild and when i rode it for about 50 miles it was ok but again now that i tighten up the bolts it is leaking.
Posted via Mobile
Posted via Mobile
