Hosk Engineering
Hosk Engineering
In the process of restoring my 1980 XS650G http://www.xs650.com/forum/showthread.php?t=25861I pulled my left side cover to adjust the clutch cable.http://www.youtube.com/watch?feature=endscreen&NR=1&v=p7V_Igyclvs The youtube video "Side cover removal" gives a great overview of this.
I discovered there was a leak on the bottom end of my engine under the side cover. After researching the issue I determined it is most likely the left main oil seal.
I added pics below if anyone has any other diagnosis. I decided I will need to replace that seal and while I'm in there I plan on replacing the Clutch Pushrod seal that I found a good video on as well
